I have an audi a4 s line 2006 model.. it has been causing start up issues for 6 months.. i had the coils replaced and the throttle body cleaned.. the start up issue got resolved but the engine started overheating.. the thermostat stays between hot and cold but the exhaust, bonnet and rubber piping heats so much that they can't be touched.. went to many mechanics but none has been able to sort the matter out..
SOURCE: my 2004 nissan armada has a intrmitting high idle issue. What is the problem
Instead of playing the guessing game get an OBDII code scan done. I know this sounds like a waste of time but there are times when the power train computer will detect issues and not display a MIL (malfunction indicator light) or as most know it the check engine light. If there is a vacuum leak, misfiring injector or coil, low fuel flow, bad sensors or any other cause this will help narrow the search down dramatically. Good Luck.
SOURCE: Issue with overheating Buick rendezvous. Bought 1
Sounds like your thermostat isn't opening properly
