Question about EliteGroup P4VMM2 Motherboard
P4vmm2 amibios via p6 - EliteGroup P4VMM2 Motherboard
Can you please help me find drivers for my motherboard p4vm2...
You can find your drivers here:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=P4M266A
You also need to know what rev. number it has to get the right driver.
It should be typed in on the mainboard.
Keyword:p4m266a Total:3 1. P4VMM2(V3.1)
BIOS - 1. Support VIA P4M266A chipset...
2. P4VMM2(V7.3)
BIOS - check sum:9B87 h 1.Support P4M266a CE...
3. P4VMM2(V7.1)
Good luck.
Feb 25, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Audio and multimedia controller p4vmm2
Hi, You can download the driver from here: http://baixardrivers.com.br/via-codec-sound-driver-k7vmm-k7vmm2-p4vmm2-p4vxasd-p4vxasd2-version-160a-driver/download-6649.htm It's where i download it every time i have a computer with that same board to reinstall. Choose Download here: download.png Download ( Win95, Win98, Win98SE, WinME, WinNT4, Win2000, WinXP) The file is small and has the name 160a.zip
Just unzip it and install. A reboot may be required.
Hope i was of any help.
Pcsimples
Feb 19, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
P4v845 via intel chipset supports ddr ram
Your motherboard supports only ddr-1 ram modules. This means you can use: pc2100 (266), pc2700(333), pc3200 (400) Mhz modules. Do not mix thease types, it will couse system instability
Good Luck,
Mark
Nov 08, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
HOW TO DOWNLOAD MERQURY SOUND DRIVERS MOTHERBOARD NUMBER IS PI845GLM-L REPLY FAST
how to download sound driver of Via P4M266A (P4VMM2 V7.3)
pls suggest me the url
Feb 03, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
CMOS SETUP WRONG
Go into the bios setup and change it
Jan 22, 2009 | EliteGroup P4VMM2 V5.X Via P4M266A...
Pc won't display but it switch on
8short Display memory read/write error The system video adapter is missing or defective
1 if it is an AGP card could be the slot for it is defective
2 Disable the onboard video chip in the bios try it again
3 If you have an old PCI videocard try that
4 if ou have 2 slots of ram chips try without one in then take it out and try the other
Feb 25, 2008 | EliteGroup P4VMM2 Motherboard
P4mmv2 motherboard
If its a P4mmv2 motherboard with AMIBIOS 686 and a VIA VT8233 chipset then the jumper setting are printed on the motherboard, but they have labeled the power switch wrong, I believe th reset switch is the power switch. This is the type of mother board that I have and I have learned this from experience. Also I read in somewhere on the internet about the problems with these types of motherboards.
Jun 04, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
Michael Thomas
Michael Thomas
Roy May
Davit Mamyan
Davit Mamyan
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
