NO, it is most likely getting in through the cowl vent area under the wipers. Normally the water drains out the inner fender, but if its clogged with leaves and pine needles, it wont drain and will fill up past the cool air intake and get into the cabin. I would pull the cowl vent grille and make sure the drains are not clogged.
SOURCE: Rain water leak
Yes Ive had this happen to my Toyota corrola and my dodge there are 2 different reasons why this is happening 1 of them it depends on if you have a sun/moon roof if so theres a vent in there so if any water or anything goes in it reroutes it too the outside of the car if its cloggeed water will spill into the car like that and just leave puddles the second thing is if you have it parked outside with trees all around theres vents up on the hood where the windsheild meets the hood they clog up so if you look along the back firewall which is under the hood all the way in the back theres a hole that gets clogged you need to clean that out and the easiest way to do that is get someone with a air compressor and blow air in that holke to push it all out it should fix all your water problems and if you have any questions let me know ill be glad to help, also please rate me.
Thanks,
Steve
SOURCE: Audi 2005 A6 4.2 Flooded cabin,Navigation not working....help!
I had a similar problem, the cabin flooded and destroyed the computer under the seat. UK car 2002 2.4 v6. There seem to be several spots to check. Remove the grommet in the metal work under the battery to allow water to drain. Check plastic strip on the lower edge of the windscreen is clean and fitting snugly against the glass. Clean out old leaves etc. And check that all is sound around the aircon filter. Good luck.
Having just repaired this problem in a 1998 Buick Regal, I can tell you that fixing the water leak is actually quite easy. It took me quite a while to track down the source of water, but I have discovered that it comes through the cabin air filter. There is a seal on the passenger side of the cowl (A two piece unit, black plastic, against the windshield) that seals it to the windshield to prevent water infiltration. It is very small and somewhat hard to miss. I took the cowl off to change the filter when I discovered this.
You can make a diverter to go over the air filter under the cowl, or even easier is to use some clear RTV silicone (avalible at any automotive and most hardware stores) and put a good bead on the old seal. When you re-install the plastic cowl, be carefull where it goes against the windshield to make sure you don't "smear" the silicone. After you re-install the plastic retainer hardware, smooth out the bead and clean up the excess silicone(a wet finger and some old cardboard works great). Let it dry and clean up the water in the passenger compartment.
Cleaning up the water is the hard part. Removing the plastic trim around the door (if you grasp the trip peices firmly they just pull up off some metal clips,but they can be quite stubborn) you will notice the carpet just pulls up. At the bottom front corner of the front doors the carpet has a plastic hook that is around one of the trim clips. Lift it off that and the rest of the carpet towards the firewall just pulls up. If it has been a long problem, your carpet may be moldy. Also, the carpet edges and some of the more hidden panel clips are very sharp and may cut you while you are poking around, so be carefull.
Since the water entered through the air filter and right over the fan, you will at minimum want to replace the filter. I had mold and moss growing on mine. My fan also squeels and chirps now, so I know it got wet. Not much to do about that but replace it or carefully lubricate the motor.
In your question you mentioned a door underneath the filter not closing. On my '98 Buick Regal there is no door or valve of any sort. The filter sits right above the fan blades. It is the cowel's job to prevent water from entering this part of the vehicle. I hope this helps you fix your problem.
SOURCE: trunk water leak 1993 buick park avenue
Mother nature is too slow in finding leaks. Have someone small get in the trunk with a flashligh and watch as you run a hose over everything. LET THE PERSON OUT!
SOURCE: after it rains water is in trunk Nissan Altima
When diagnosing a water leak, here's a handy tip. Check the accumulated water. If the water is dirty, look for leaks from the underside of the vehicle (floor, wheelwells, etc). If the accumulated water is clean, look for leaks from the topside of the vehicle (trunk seal, window seal, etc). To find where the water is coming from, shut yourself in the trunk with a flashlight and have an assistant run water over the trunk with a garden hose. You may have to remove some of the interior trunk trim to see exactly were the water is coming from, but chances are you'll find it. Also another common cause of water leaks are from impact damage, so check for collision damage repair. while your in there. -hope this helps.
