No plastic straps are usually not covered by warrenty. If you live next to a ski resort with a shop im sure they will have a replacement for about 10 buck MAX. Otherwise check at your sporting goods stores(I know scheels carrys them).
You can replace battery's by lifting the cover by pulling the strap if it is showing if not use a plastic card or plastic knife rise the edge slightly then pull on covers notch with your fingernail to remove cover completely . 2) insert 2 AAA battery's making sure to align the positive & Negative ends correctly . 3) Align the battery cover and make sure you press all the catches .
You have to lock the silver tab all the way back (it will click and lay flat). You have to keep that down with your thumb. There are two black plastic levers which hold the ratchet strap in place. You have to press them down towards the boot (not together towards the strap). When they are new this is a bit difficult. You may have to do one side at a time (just remember to keep the metal tab in its laid back position or it will snap shut and you will have to start all over again). Once you have the lever stop checks above the ratchet bevels of the strap, you will be able to pull the strap back out. Open and close the strap a few times to get the "new" out of it and it will function fine.
Found this solution on this website, and works great!
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
This is an easy repair and the parts are at walmart or just about anywhere. Just get a new flapper and wrap it around the overflow pipe and hook up the chain or strap, whatever it comes with. Hope this helps.
no u can use a socket 1"1/8 i think, but Lisle,(Lile) makes a socket just for the cap its about 13 or 14 dollars it doesent marr the top of the oil filter cap
You can buy replacement straps at HighChairBelts.com. One set was $9 with shipping but I bought three for $17 with FREE shipping. I sewed the ends of one set together and use it with my baby's grocery cart cover rather than relying on the filthy one provided on some carts. EWE... lol
You can repair it if, you know how to mold and work plastic. Or, you may be able to use small screws if you don't mind the ugly. Personally, I would replace the cover. If your printer is under warranty, this may be a defect in their design. Try calling Brother to find out if they'll fix it for nothing.
Go to the canon website, and into their tech solution area, type in your printer model, and follow their guide. Also, you can order the new part from them, they will be able to tell you what the part is, and how to install it. They will also tell you that you will void your warranty with self fixing!
