You do have to make sure to switch the settings to an external antenna. You also will have to check that you have what is an analog signal available to you. If you antenna is analog it will only get analog broadcast. You may also need to switch to a digital tv antenna, The other thing is the range of you antenna. Most indoors, in a congested area will only pull in signal from about 20 to 25 miles out.
