Question about Toshiba DKT-2010H Corded Phone
Switch unable to transfer calls to extension
Hi, Anyone able to help?! The Switch cannot transfer calls to one extension in office. The extension can make calls and listen to voicemails but nothing can be put through to it! Very annoying so please help!!
Thanks.
Posted by cdelahunty on
  • Carl Navarro
    Carl Navarro May 11, 2010
    In my limited knowledge of Strategy voice mail, there is a command to block transfers. It may be changeable from the extension alone as part of the options, or the administrator may have to fix it.
Anonymous
  • 38 Answers
Check the extn number izzit the correct number
try use that phone call to displayed phone to c wat the extn number
Posted on May 31, 2009
george peters
    President:
  • Toshiba Master
  • 860 Answers
Sounds like the station is in do not disturb mode.Internal, external and transfered calls do not ring but the station can still make calls. there should be a lit button on the set maybe marked do not disturb or DND. press the button again to turn the led off. hope that helps
Posted on Mar 24, 2009
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
Unable to transfer calls from extensions off Hymax 32i PABX system
Not sure about the Hymax, but most all PBX call transfer switching works via a switchook flash and then when you get ther second dial tone you dial the extension. When the transfer party answers you either hang up or flash the switchook and have a three way conversation.
Aug 26, 2014 | Lands Phones
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
How do I transfer calls to someone else in the office using Norstar T7316 phone?
If your telephone doesn't have a transfer button programmed press feature *3, the button you want the transfer button to be, and enter feature 70. While on the call press the transfer button (or press feature 70) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after youpress transfer and dial the extension and they'll get the call without screening.
Sep 28, 2009 | NorStar T7316E Corded Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
How to transfer a call
While on the call press the transfer button (above the hold key) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after you dial the extension and they'll get the call without screening.
Sep 17, 2009 | Lucent PARTNER18 Corded Phone
Unable to retrieve startalk messages from remote location
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
Jul 28, 2009 | NorStar Startalk Flash 2 Phone
TRANSFER TO WRONG EXTENSION
This will be an easy fix. It is your night AA selector code. Did you resolve this?
Apr 07, 2009 | AT&T Lucent Merlin SP 34 Phone
Transferred calls
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
May 07, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Toshiba DKT-2010H Corded Phone Logo
207 people viewed this question
Top Toshiba Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
