Question about Samsung HCL4715W 47" Rear Projection Television
SOURCE: samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Posted on Sep 25, 2007
SOURCE: Samsung HCL5515w
Usually if some parts on the board burnt on that model it can be caused by leaky tubes. Meaning the coolant from the crt's has dripped out. If burnt components are beneath any of the tubes, inspect very closely for liquid substance having leaked down from coolant chambers above. If this has happened you must seal leaky gaskets before going through any trouble of pcb repair.If burnt parts are not below tubes, most common cause is bad convergence ic's. At any rate, service info avail online or at samsung.com or 1800samsung. Hope this helps.
Posted on May 29, 2008
SOURCE: samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Posted on Dec 27, 2008
Sep 05, 2016 | Electrolux Washing Machines
Dec 13, 2014 | Electrolux Washing Machines
Jun 30, 2011 | Heating & Cooling
Mar 13, 2011 | Washing Machines
Nov 07, 2009 | Refrigerators
Aug 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Aug 14, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
360 people viewed this question
