You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
the relay is stuck causing the blinkers to remain on usually as heat builds up in the relay it causes the metal contact to expand and flip off and once its cooled down it can make contact once again and give power to the blinkers this happens very quickly thus you get the turn signals blinking when turned on and will hear a clicking sound coming from the relay switch ,unless its faulty and needs to be replaced .
Sharp LED/LCD EEP cleared Step
Remove Mains Plug
Press On/Off Switch from LED/LCD Panel
Press Ch Down & Input Switch together and plug in mains cord
LED/LCD will start
5
"K" will appier on Screen
6
Press Ch Down & Vol Down from LED/LED Panel
7
1/9 Page will appier on Screen
8
Go to 9/10 page by pressing Up & Down arrow of remote
9
Select EEP Cleared
10
Press ok button from remote
11
On Screen dispay EEP running
12
Remove Mains Plug after complete EEP Run
13
Restart LED/LCD
Hi, TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front. Hope these info will help you. Thanks.
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
