Can not figure out that is the XFX 9500GT (1GB DDR2) card compatible with my Dell GX280 (SMALL DEXTOP COMPUTER)?
->Card specs: pci-express 2.0/ low profile compatible/350watts power supply
->Sysem specs: Intel D915-dell bios/ 2.8Ghz HT(1MB cahe/800mhz bus)/250gb hdd sata2/ Pci-express x16 slot/ 200watts Dell Orignal Supply
looking at supply required is 350watts but system has only 200watts (dell orignal), the vendors here says that dell supply IS powerfull enough to load the card....
pls Advice thet would it work... and work great or is there any prob....thanks in advance
So if this is a slimline pc you are kind of limited in upgrade options
space being the biggest , then being followed with cooling ability, the best advice I can give you if specs say 350 is needed i wouldn't chance having the card pull more of a load off of the PSU than what is rated for it. Hope this helps
