Is it support pentium 4 for foxconn motherboard n15235
Is it support pentium 4 for foxconn motherboard n15235?
Posted by rathanshetty on
Anonymous
  • 3 Answers
This is a socket 775 boards and it should support Pentium 4 processors. TC
Posted on Mar 24, 2009
Overheat errorhow to fix the problemi have Foxconn n15235 G41MD-Vwith pentium CPU
Download and run speed fan and monitor your temperatures to make sure there are no other possible issues. If the computer is unable to turn on, remove the power cable from the power supply on the back of the computer, open the tower, and re-seat all connections including the CPU. I would imagine since the motherboard is a socket 775 you will more than likely you will need to re-apply thermal paste (http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007) to the heat sink or you need a new heat sink all together. Since your motherboard is a socket 775, here are a few heatsink/CPU cooler upgrades that may help the problem:
10$ and shorter overall profile since the case size is unknown
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186070
25$ and a bit taller, but I successfully used this heatsink for 7 years before it gave up.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Jan 16, 2014 | Computers & Internet
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Mark
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
Drivers
for drivers on M/B FOXCONN N15235 all dirvers go to www.quebex.com, also will include the direct link, and click on model APOLO_48XX and have fun downloading all needed drivers...
http://www.qbex.com/website/downloads.php?osCsid=83c184775bfaf6771df03e7fc3bdb41a
Jun 17, 2009 | Computers & Internet
Foxconn board
the problem is software, there is nothing wrong with the processor as the machine boots showing that the processor works, have a look at your memory and clean it.
This problem occurs because there is a limited amount of kernel space available for kernel drivers so there is not enough stack space for processing the exception. its an operating system problem, try and boot into safe mode and perform a system restore by pressing F8 on boot up
good luck
Nov 14, 2008 | Foxconn Computers & Internet
Foxconn manual for a n15235
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom ([email protected])
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
405 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
