I bough a VX-3000 lifecam and installed it on my lap top. It gave me the set up wizard to check and make sure the video, and audio were working. I decided to see if it worked and hopped onto my windows live messenger. I went to invite a friend but I recieved this message in bold print... :
"We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again"
I've tried everything. I've deleted the software over three times and tried to reinstall it.... I even restarted my computer after I installed it and tried it again... Please, any input would be vastly appreciated!
My Creative Live! Cam worked great with WLM until I updated WLM. Now I get the error:
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
when I expand WLM and go into the Audio and Video setup menu I get this error:
We are unable to run audio and video setup
Normal
0
Also send this to your family
and friends so they have their computer setup properly.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
To install Windows Live Messenger, double click on this site
to download then install. (http://www.soft32.com/download_30.html
Windows Live Messenger:
v
NOTE: Your audio and
video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype http://www.skype.com/intl/en-gb/download... )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/detai...
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
I'll give you two things you can do. Read them all the way through and then follow the instructions and your camera should work okay.
This ptogram will eliminate your problem of the camera being busy or being used by another program. Really works great.
Copy this site and paste it in your web browser address bar and hit ENTER.
http://download.cnet.com/SplitCam/3000-2...
And then click on Download Now (3.5MB)
1. Install Splitcam saying yes to everything during installation including the any warnings.
2. Then run the Splitcam program by double clicking the downloaded program.
3. Clicked on "Video" at the bottom right of the program window and selected your cmera.
Note: This will result in your camera being switched on and viewable in the
SplitCam program.
4. Opened up Skype (or other messengers) and go to "Tools" then "Options" then "Video settings."
5. Also setup your “Audio” while you are there.
6. Selected "SplitCam Capture" as my webcam, then click on save.
7. Webcam image will appeared in Skype or what ever messenger you are using.
Next:
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype http://www.skype.com/intl/en-gb/download... set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
Microphone
Speaker
Camera
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will cause
the drivers to be corrupt and render the camera unusable till reinstalled it properly.
