for first my friend what kind of car do you have,second what kind of engine - diesel,petrol, and last year of manufacture. After this information I believe we will help you with the correct answer.
Apparently you don't use the unit long enough to get it good and hot. Then condensate builds up and falls into the oil. ( It's like turning your car ac on high defrost during a summer morning. Where the cold air blows on the windshield condensate forms on the outside). Same principal. It gets just warm enough to cause condensate to form on the inside of the compressor. To correct run longer or you can purchase a heater to go in the oil sump or keep the oil changed. Don't wait until it turns milky.
That is the oil pressure sending unit, and the only fix is to replace it. It screws in & out like a bolt. Be sure to put a sealant of some kind, or thread tape, on the threads of the new one before you install it. It may take a special wrench or socket that the parts store should have or may even let you borrow it. Just firmly snug it in. Don't crank it as hard as you can. It will snap off, and you'll be walking! Finally, don't forget to hook the wire back up!!
call your auto parts store, we don't know if it's the air filter, fuel filter, oil filter, cabin filter, pvc system filter, transmission filter, p/s filter, don't know what kind of car, size of engine, need to know more information that I NEED A FILTER.
Well i check my oil hot & i keep it 1/2 way beteween full & add too much pushes oil out breather/ air filter area i thinh youll be fine wash off & watch .. clean a/c A heads up I have gottin good help at harleytalking.con... good luck ';';'; oh yea pressure on mine is at idle is 20 psi 30@ 2000 rpms oil temp 225 hot tom..;';'
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
ENGINE OIL 20/50.
