Question about Crosley Audio Players & Recorders
Crosely won't play usb
My Crosley turntable has an USB port for digital audio. I've connected my iPod to the adaptor and of course plugged it in. I've turned the knob to the SD/USB selection on the front, but it won't play. Everything else seems obvious. Why won't it play?
    Genius:
  • Crosley Master
  • 1,054 Answers
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Posted on Jun 18, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: AC adaptor cord
Try a Radio Shack universal replacement power supply like 273-1773 or 273-1776 or 273-1667 with the proper "Adaptaplug" that goes with it. It should do nicely and be sure to observer the proper polarity of the plug so that it will match your unit. Good luck.
Posted on Feb 04, 2007
ravi chavan
  • 238 Answers
SOURCE: mp3/iPod compatible connection
hi , instade of going thru USB, just plug a stereo RC pin to the Headphone socket of the iPod and the other RC connectors to the line in of the stereo system, play the Ipod, u can now hear it from ur steroe system.let me know
Posted on Jan 03, 2008
Anonymous
SOURCE: Low Volume from right speaker of entertainment center - turntable only
Hi There thanks for your very good desctiption of the problem it really helps to have a lot of detail...
There are Mono and stereo types of stylis cartridges and it sounds like you have a mono equipped into a stereo amplifier..
If there are 4 small coloured wires visible under the stylis then
its a stereo stylis and should work, have a close look and maybe one of the small wires has dropped of the small pins on the back opf the stylis cartridge.
If there only two wires visible then its a mono cartridge and this is why you only have sound from one channel..
So answer is wires dropped of the stylis.
or
Wrong type of stylis cartridge.
or
if there are four wires and thay all look connected then perhaps the stylis is faulty and you need to replace it...
Cheers from YU BEUT
Posted on Feb 03, 2008
kruddydude
  • 5 Answers
SOURCE: IPod issues
Buy a headphone to AUX cable and plug it into the AUX port beside the headphone jack.
Kruddy
Posted on Feb 04, 2008
alexhor
Alex Beluza
  • 28 Answers
SOURCE: ipod wont play on stereo
Re-check your usb cable, try to use the usb cable specified for use only by RCA RS2664b to connect to your ipod, if it doesn't work use the usb cable specified for your ipod because differrent appliances have diffrnt cable configurations.. ;-) hope this advice help you..... good day!
Posted on May 24, 2009
Crosley turntable when not recognized by PC
Install the device driver from Crosley.
Sep 17, 2015 | Computers & Internet
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Crosley turntable won't play through home stereo
Quite possibly the sockets you put the deck is not designed for the playback of phono signals. They should be marked "phono".
Other issues are earth connections.
Mar 17, 2013 | Audio Players & Recorders
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
How to buy Crosely USB Tech Turntable in India at Kolkata and what is the price?
THE CROSLEY TURNTABLES MAY BE PROCURED FROM EBAY GLOBAL EASY BUY OR SHOPYOURWORLD IN INDIA
SIDDHARTH
Aug 13, 2010 | Crosley CR249TA Turntable
HOW DO I PLUG THE SCANNER INTO MY LAP TOP I CAN ONLY SEE SCART NOT USB PORTS
Mustek 1200 is an old scanner so it's normal that it hasn't usb connection. You have to buy a USB to parallel port adaptor (about 10Euros) in order to connect the scanner with your laptop. Of course you 're gonna use the power supply that you 've got with the scanner in order to power up the scanner.
Stelios.
Feb 20, 2010 | Mustek Plug-n-Scan 1200 CP Flatbed Scanner
I own a Bush RP A3 turntable and radio with CD=need instructions
FIRST READ ALL, then check cables u need, then proceed!
u want to connect turntable to pc - don't need usb
or connect turntable audio-out to radio/cd.player and this combination to pc?
recording on mp3 player is an option, but quality else is much better!
u will need for case 1:
a pc-program called audio-grabber 1.83, downloadable on the inet
a pc with soundcard that has audio-in (3.5mmplug, also used for small microphones
and earphones)
and at least win 2000 on it
the cable connecting turntable and pc(see following)
if turntable has audio-out like
- two red and black-cinch ports (to connect to amplifier/radio)
you need adaptor cable from 2-plug (red/black, male) to 3.5mm audio-in (similiar tor headphones,
male version)
- turn-table has small(3.5mm) or big (6.3mm) earphone-in,
use signal from here, connect tt with pc using adaptor cable
(3.5mm, male + 6.3 to 3.5mm separate adappor (small earphone to fit in big) at one end and
3.5mm, male to plug into pc-soundcard's audio in)
do all the pluggin', then turn on PC, start up audiograbber, turn on tt let play, press record button
in audio grabber, make an test recording, half a minute will do.
now let audiograbber sample theresulting .ogg file to test.mp3 and test-play it with windows media player on your pc
voila une mp3 !
to have every song from vinyl sepatetly as mp3,
record and name it serately in audiograbber, let it sample down to mp3 and enjoy!
u may have to fiddle through audio-grabber's menus and adjust volume, sample rate(quality of mp3)
to your comfort, but now u own legal copies of your vinyls, with still the analog vinyl tickle
and know how to use audio grabber as an recording tool for any music that is played on or put into a pc, incl. webradio other webcasts
please don't stop the music
Jun 18, 2009 | Audio Players & Recorders
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Apr 05, 2008 | Televison & Video
Ipode
The problem is that Apple rewired the USB port on both the ITOUCH and the IPHONE. hey've made it an Apple only connection now . Run out of your headphones to the AUX in on radio
Mar 08, 2008 | Kenwood KDC-MP435U CD Player
137 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
