Question about Akai LCT3201AD 32 in. LCD Television
Power when plug in a light comes on but will not turn on when i push the button
Posted by Kyra Beckles on
    Top Expert:
  • Akai Master
  • 76,534 Answers
That'e standby light comes ON and get OFF I assues. If so the problem should be its main board itself. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Posted on Jun 17, 2013
I hav icraig slimbook model CLP288 red light that indicates its chargeing comes on but I push power button green light very brief comes on then off screen never comes on .plz help
Try plugging the charger into a wall outlet if you are currently plugging it in a power strip. If you are not try plugging it in another wall outlet. If that doesn't work you can try a hard reboot if the battery is accessible. To do this turn off the slimbook, unplug it, take out the battery and hold the power button down for 30 seconds. Once done put the battery back in, plug it back in and turn the slimbook back on.
For other IT soultions try visiting: https://www.youtube.com/user/jrlake2414?sub_confirmation=1
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Jan 24, 2016 | Computers & Internet
My x-box won't turn on with everything plugged in
Hi check on the power brick that when you switch it on at the mains you get the orange light on the power brick, if you have this watch this light as you press the on button on the console if it turns red on the power brick then you have internal error on your xbox, if it stays orange then try taking out the power lead out of the back of the xbox 360 then push it back in sometimes if you dont get it pushed in far enough it wont work push it in as hard as you can then double check by pushing it back in then try pressing the on button.
if when you turn it on at mains you dont have any lights light up on the power brick then this could mean you either need to change the fuse in the plug or the power brick has over heated and needs replacing, if you do have an orange light on it then instead of pressing the on button on the xbox try pressing the dvd drive open button and see if that then switches it on.
let me know what light you get on the power brick and then ill do my best to assist you further.
most of the time its just because you dont push the power lead in the back of the xbox far enough, you can push it in thinking its in far enough when its not try pushing it in that little bit further and you should find it will come on.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 15, 2010 | Microsoft Xbox 360 Console
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Akai LCT3201AD 32 in. LCD Television Logo
23 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
