The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
When you reboot the computer, that message should go away. Use an external SD card reader and transfer your photos that way. They are inexpensive and relieves the need to connect the camera to the PC. It will transfer your photos much quicker too
Is the camera recognised by the pc as a usb 'drive'.?? If not try another cable. If another cable does not help, then the fault could be with the camera itself.
Try inserting the card in a separate card reader attached to a pc - if you can see the latest pics taken, then the camera is taking pics ok - and we are back to the transfer problem.
If you can see the pics in your 'my computer' then you can copy or move them onto your pc's hard drive. The fault then could be your Nikon transfer program. Try reloading the software as it may be corrupted on your pc..
Are your batteries fully charged? Direct Camera to PC transfer uses a lot of power. Some early L100s could not use rechargable batteries - unless you downloaded new firmware fron Nikon. That needs a card-reader. Once you have a card-reader, use this to download the pics, so that the PC supplies all the power.
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Transferring images from the camera to the computer requires a lot of battery power. It is recommended to use the AC adapter when transferring pictures to conserve battery life. If not using the AC adapter, make sure your batteries are fully charged and use the highest possible serial speed when connecting the camera to the computer. After transferring your images remember to shut off the camera, otherwise the camera will remain "awake" and will continue to wear down the batteries.
The LCD display also uses much battery power and should be used sparingly when trying to conserve power usage.
Battery life can be improved by using AA sized lithium batteries, rechargeable AA Ni-Cad batteries, or rechargeable AA Ni-MH batteries instead of AA sized alkaline batteries.
