Re: It's connected fine, now it won't connect, what's up?...
Delete the problem unit off the phone's list then turn the phone off then back on. Next you will have to go through the pairing procedure for the headset again.
Before you use your Jabra BT350, you need to pair it with your mobile phone. 1. Put the headset in pairing mode • Make sure the headset is off. • Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ‘discover’ the Jabra BT350 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
dude first of all you have to reset the passcode of your jebra bt350 then connect it from your parents mobile.
how to reset---- Press settings/connections/bluetooth/check both boxes; turn on, and
make discoverable/click devices tab/turn the jabra off/then hold the
ear button till the blue light is solid (not blinking)/click new
partnership on the phone/click 0000 for the passcode. it should hook up.
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
This is what I did: 1. open the headset by following these steps: http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/ 2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v. 3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine. 4. Reassemble and hope your headset is back to business.
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual): 1. Put the headset in pairing mode • Make sure the headset is off. • Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.) 2. Set your Bluetooth phone to ‘discover’ the Jabra BT350 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device. 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at [email protected]
