We have a Whirlpool Duet model# 6HW9100LW1 frontloader, it just started making noise from back or bottom like a rattling noise or clicking during wash cycle, and it goes through most of cycle and then stops and gives error F2 on digital read out and it stops, and it will not drain water that is in unit it just sits there like it is trying to drain water or do something but only makes that clicking or rattling noise from back or bottom of machine, it does this no matter what cycle we choose heavy wash, med, ect. Thanks for any help that can be given we are not sure what the next step to fixing this problem would be.... Tobin
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
