Question about Kodak Photography
The Kodak Moviedeck 435 is working but no light is coming on, Bulb looks good. Is there a special switch for it?
4 Related Answers
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: refrigerator light doesn't work. switch and bulb good.
If you have an elect. meter, you can tape the door switch closed, remove bulb, and touch your leads, one to the center tab on the socket and the other to the threaded portion of the socket, where the bulb screws in and you should have 120volts. If you are sure you have no power, unplug it and try and gently pull out the switch. This is the only thing between the light and main power below.The switch only connects to one of the 2 wires and a connector may have burned or come loose.If you have power to one side of the switch to ground, and its taped closed, and have no power coming out the other side, then you have a faulty switch.You can get a socket and or switch at your local appliance parts house. Just take the model, serial, name, and product # if there is one and they can match one up for you. I'm betting its the door switch.
sincerely, shastalaker7
Posted on Oct 30, 2009
Jim Auburn
  • 412 Answers
SOURCE: manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Posted on Jun 25, 2012
bigdawg7110
  • 3 Answers
SOURCE: kodak moviedeck 475 Film
There is a small plastic gear that disintegrates with age on these units. The gear is worn and cannot turn the larger gear to thread the film. Good luck finding parts. There is one place that sells parts but I think they gauge the public
Posted on Jul 13, 2013
oilyspill
jack layton
  • 5315 Answers
SOURCE: I have 1997 Jetta all brake lights quit working. Fuses are good bulbs look good and brake light switch looks ok could a bulb be bad and cause all three to go out?
I'd want to check voltage and ground for the stop lamps. Use a test light.
In the diagram for brake switch, the top wire is voltage, hot all the time, use a test lite to check for voltage, that circuit is fuse protected.
The lower wire in the picture goes hot when brake switch is activated and carries voltage to lamps. Like I said, the lamps need voltage and ground.
Posted on Nov 05, 2016
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
Kodak 5200 focus slide not working
The auto-focus system requires adjustment / set-up with special tools if the auto-focus no longer functions correctly. Before ordering the tools from: www.micro-tools.com
check a couple of things:
1. Is the "Auto-Focus on-off Switch" in the "ON" position?
2. Put a slide that is as dark as possible in the slide gate. Power on, lamp on. Look down into the gate, on the front side of the slide. You should see a "S"-shaped light near the center of the slide.
If you have validated both of the conditions above, then I would contact my friends at micro-tools for the special tools. They should be able to provide you with adjustment instructions.
Good Luck !! Jim
Oct 18, 2013 | Kodak ATS Ektagraphic Slide Projector
Take up reel not spinning
FYI, service manual here: http://www.micro-tools.net/pdf/kodak/m-series.pdf
Sep 29, 2013 | Kodak Moviedeck 475 Super 8 and 8mm Movie...
The driver side running lights don't work on my 2007 hyundai elantra. brake light, blinkers and headlights all work and the bulbs are good because they flash when i lock car with the fab. but they don't...
brake lights and blinkers use the sale filament in the bulb
the running light is the other (in a dual filament bulb)
you may have a poor connection or a break inside the bulb base.
test with a known good bulb.
the next place to look is the connector on the light switch and the joint where the running lights split off.
Sep 12, 2013 | Hyundai Motor 2003 Elantra
Manual for kodak ektasound moviedeck projector 275
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
Fan works, light won't come on. bulb tested fine.
Jason's analysis above is correct! You can order the Thermal Fuses and Lamps (if you need them) from: www.micro-tools.com
Good Luck !! Jim
Aug 27, 2009 | Kodak Ektagraphic III E Plus Slide...
Kodak moviedeck 475 Film won't thread
Oct 15, 2008 | Kodak Cameras
Photography Logo
181 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
