My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The camera still indicates card locked with a new card inserted. same thing, sd500 ,error says memory card locked and it is not ! how do we correct Memory card says card locked, but when checking the lock/unlock button, lock is off. I have the same problem!!!!!!!! It's not the card, its the camera. I brought mine to the repair shop (Canon Philippines) and the technician said there's a part that needs to be replaced, yes and guess what??????? It cost more than $120.00! OMG!!!!!!!!!!! Aaarrgghhhh!
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Posted on Jun 18, 2009
I FIXED MINE! First, let me preface this response with a "no, really!"... okay, here goes.
My wife has a PowerShot SD800 IS that has functioned flawlessly for 4 years... until we were on vacation on Long Island this past May. A week or so into removed the SD card out to look at pictures on a friend's computer, and when we put it back in the camera, we got the "Chip Locked!" message. Problem is, the chip is an EyeFi card WHICH HAS NO SLIDER LOCKING MECHANISM AT ALL! Even using a different chip resulted in the same "Chip Locked!" message. After scanning Google for user-suggested fixes, including removing both the removable and internal battery (I took the camera almost completely apart and could not find an internal battery... but it's gotta be in there somewhere) and letting the camera do a "hard reset," nothing rid the display of the "Chip Locked!" message.
So, I got to thinking... the camera determines if the chip is locked (if the chip has a lock) via a sensor associated with the little gold connectors on the "business end" of the chip. Applying the solution logic from another user's post (their lens failing to operate, due to sand creeping into the camera), I thought "what if there's a grain of sand on the "chip lock" sensor/connector in the camera's SD card slot. So, I took a can of air, gave a quick little blast in the slot and "Voila!" no more "Chip Locked!" message! Everything works perfectly again, any chip, full function.
Sometimes it's the most obvious thing that is the hardest to see! Give it a try...hope it works for you as well!
Posted on Jul 18, 2009
Remove the card and slide the lock on into the opposite (locked) position and then back again and try in camera. if that does not work, format the card in your camera.
Posted on May 01, 2009
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Feb 21, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
May 11, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Nov 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Oct 01, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
592 people viewed this question
thanks fblock!! it actually worked!!
