Question about Gemini Sound Products Music
I HAVE A GEMINI CD200 DUAL CD PLAYER. ONE OF THE CD TRAYS CAME OFF IT'S TRACK, WHERE CAN I GET IT REPAIRED?
I have a Gemini CFX-50 dual cd player. The left tray is not reading the cd whenever I put it in. I am getting a message "no disk". the right tray works fine. What could be the problem? Please help!
If the motor is spinning the disc, then your problem is with the laser. It either needs to be cleaned or replaced. Cleaning can be done with a regular laser lens cleaning disc, available at any store that sells electronics. A replacement lens assembly can be picked up at any store that specializes in electronics.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Oct 21, 2013 | Gemini Sound Products Gemini CFX 50 Dual...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
Dec 06, 2011 | Gemini Sound Products Gemini CDJ 203...
Help my gemini cdmp-6000 service manual
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 03, 2011 | Gemini Sound Products Gemini Cdmp-6000...
I just bought the cdmp - 6000 and the cd player and usb port plays the music like its a short in my speakers. Everything is new i unpluged re-hooked up everything and still the same probloem. Please help?
what do u mean it sounds like ****? it could be a dozen things cables loose wires, basically check n recheck everything n then just the dj stuff by itself that will narrow it down so we know what it is.
May 27, 2011 | Gemini Sound Products Gemini CDMP6000 Dual...
Gemini cdj600 not reading mp3, wmv format
WMV is a video format. You need to convert to MP3
Feb 24, 2011 | Gemini Sound Products Gemini CDJ 600...
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Nov 27, 2010 | Gemini Sound Products Gemini Cdmp-6000...
Music Logo
51 people viewed this question
Top Gemini Sound Products Music Experts
Colin Stickland
Colin Stickland
rhodesworks
Vuk B
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
