Cameras Logo
Anonymous Posted on Jun 16, 2013
Pc new computer has windows 7 professional. can't download pictures from camera as it's originally for windows 98 or xp. is there a download that will fix this??
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1149
Points
Cannot upload pictures from my Nikon Coolpix to computer
How to install GE E1255W Digital Camera driver for Windows 7?
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Jan 05, 2013 • Cameras
1helpful
E900 wont upload pictures to my PC
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Why my samsung wb 700 camera not connect with the windows 7 pc.but xp lap identifies the camera. system requirments for camera are windows 2000/xp/vista. Is this the problem or should i install suitab
1helpful
What's your problem?why my samsung wb 700 camera not connect with the windows 7 pc.but xp lap identifies the camera. system requirments for camera are windows 2000/xp/vista. Is this the problem or
Just installed Micrografx Picture Publisher 10 from the original disc. When I try to run it, I get the following error Micrografx Picture Publisher Digital Camera Edition has stopped working It says...
I had the same message trying vista. Windows 7 offers running older programs in XP or even Win 98 SE mode. That fixed the problem for me. Further I recommend running it as administrator. Hope it helps.
Walter
7helpful
We swirched from windows 98 to windows 7. our
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Incompatibility canon camera powershot a520 and windows7
1helpful
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Picture project not detecting camera since installed windows 7, how do we download pictures now. camera is being detected by pc so it doesnt appear to be a hardware issue, nikon resource center say they...
You could try the folowings:
1) Run your picture project program under XP SP 2 'compatibilty mode'.
2) Run the picture project program in XP mode if your computer and version of Windows 7 allows it (eg. Professional or Ultimate versions but your computer processor will need to support 'hardware virtualization).
3) Run the program in a Virtual machine with XP installed: I would use Sun VirtualBox which is free and does not need hardware virtualisation (unlike windows 7 'native' XP mode or VPC2007).
As you can see, you do have some options to overcome Windows 7 shortcomings! Hope it helps.
Jan 30, 2010 • Cameras
Mega+2 Pictures Grayed Out (can't be selected for download)
With Windows 2000/XP operating system no Camera software is needed.
If you can switch back to XP and leave the camera software out - Windows can do it all by its self.
If you are still in 98 and it is USB able then this same may be true {I have forgotten] The idea is that camera software general is a bit naff or worst an absolute hindrance.
Plugging a camera into a USB socket is the same as plugging in an external drive
That is what in fact the computer sees
Top eVision Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an eVision Camera Expert? Answer questions, earn points and help others
