Question about Sport & Outdoor - Others
HOW TO PUT A TENT UP - Sport & Outdoor - Others
Posted by Trevor Reay on
Elizabeth Elgar
    New Friend:
Hi I have the full instructions for pitching the Lichfield Condor Family Dome tent with 2 bedrooms if anyone wants a copy happy to email it :)
Posted on Jul 07, 2013
Richard Saada
Yes please would love a copy email [email protected]
many thanks
Posted on Aug 28, 2014
How do i put up a tent
Jo, you gave no make or model #, so Check the attached links,instruction and guides, the last link shows different type which you can google search for setup also.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wilderness Survival How to Put Up Dome Tent
How to set up 4 man tent
Instructions for Putting Up Camping Tent
Types of tent
Apr 05, 2016 | Sport & Outdoor - Others
Need instructions for putting up a tent please
I don't know what kind of tent you have but there are many videos on youtube.
erecting tent YouTube
building tent YouTube
making tent YouTube
Aug 15, 2014 | Sport & Outdoor - Others
How do i put buzz lightyear tent together
If it is like mine (year, etc) you simply first lay out the ground cloth (if you have one) long-wise, then lay the tent body on top of the ground cloth. Next, stake out both ends of the tent (at head and feet of tent). Now put your poll sets together (the large one is for near the head of the tent, the short for the near foot of the tent). Go ahead and put the polls in the aligned grommets (matching the ground cloth grommets with the tent-body grommets). Once you have the two polls inserted, then clip your tent to them. Now, with your tent erect, Place your fly on top and drape over the tent accordingly; then fasten the fly to the tent using the belt-type nylon clips to do so. In this case the fly does not need to be "staked", rather "belt-clipped" together instead. That's it, your're done. Don't be alarmed if your tent floor seems as though it's lifting off the ground in some areas, this is normal. Just go ahead and put your bed role in the tent and prepare your area as normal.
Aug 08, 2012 | Playhut Disney Pixar Toy Story Buzz...
Can I use a grill under my tent?
Absolutely not, the smoke from a grill will damage the fabric of the tent. All grills must be far enough away from the tent so that no smoke is allowed to enter the tent. The tent is made of very flammable fabrics so there is a great risk of causing a fire while grilling under a tent, just put the grill outside it will be more pleasant to stay inside not smoky tent.
Jul 31, 2012 | Camping, Backpacking & Hiking
Can I heat up my tent?
Colman and other manufacturers sell tent heaters. Use appropriate caution with heat around synthetic tents, and with fuel-burning appliances inside a tent. RTFM (Read the Flipping Manual!)
Jul 30, 2012 | Camping, Backpacking & Hiking
Coleman cobra 3
I wasn't able to find the manual for this exact tent, but you can find the instructional pdf for a very similar Coleman tent here: http://images.owneriq.net/download/images/a/a2b135c5-2f4c-f344-4952-99319efb54aa-000001.png
The video below may also help you see what the tent looks like once it has been put together (different angles may be helpful). Best of luck!
Jul 08, 2012 | Coleman Cobra 3 Three Person Backpacking...
I need the instructions to Put together a Dora Bed Tent please
I need instructions to put together a Dora bed tent please
Jan 20, 2011 | Nickelodeon Dora Bed Tent
Can I download a user manual for Tadpole 23 tent?
I wasn't able to find a manual, but after looking at the website, the tent looks fairly easy to set up.
Lay the tent out flat and peg down four corners. Then take the longest two poles and put them diagonally through the tent sleeves. Then, put the third pole (for the doorway) through it's sleeves.
Next, you'll have to put the pole point into the hole at either end. Then, go to the other end and bend the pole until you can get the other end in the corresponding hole. Do this for the other diagonal and the tent should be standing. The last one is the door pole
Last, lay the rain cover over the tent. There should be some hooks to strap the hood down near the poles. Don't worry about any strings, etc. Those are for high winds and almost never needed. Good luck
Jun 14, 2009 | The North Face Tadpole 23 Tent
Sport & Outdoor - Others Logo
329 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
