I had a friend, who has put in stereos before, try to put this in my 99' Jeep but the volume doesn't work for some reason. All the necessary wires are matched up properly and everything works except the volume. Worst case is I take it to be done professionally, hopefully, but I would like to save a bit of money. Thanks for the help!
SOURCE: Flip bit not working KDC-7090R
hi its going to be the flexi that connects the panel to the main pcb. you can buy a repair kit @ www.carradiospares.co.uk
Regards
Mark
Blue ICE
SOURCE: wiring for a 99 jeep cherokee
On your vehicle there should be two male plugs from the back of the radio, one black and one gray. The simplest thing to do is get an after market harness but if you really need the wiring,here you go:
12V+ Pink/Yellow
Acc Red/White
Ground Black
Illumination (not really needed) Orange/Brown
Dimmer (also not needed) Black/Light Blue
Speakers:
FL + Dark Green
FL - Brown/Red
FR + Violet
FR - Dark Blue/Red
RL + Brown/Yellow
RL - Brown/Light Blue
RR + Darl Blue/White
RR - Dark Blue/Orange
SOURCE: my car stereo cd player no sound
what are you trying to plug into USB? if an iped it required Kenwood IP200 Adapter
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
SOURCE: Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
