Question about Fuji FinePix S5000 Digital Camera
Setting date how do i make the date appear on my photos and not just appear on the screen
Posted by tinabrett on
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    u cannot do this so simple !!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Dec 26, 2012
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
Apr 19, 2012 | Konica Minolta DiMAGE G500 Digital Camera
How do I change the date and time on a vivcam8225
Hello and welcome to FixYa!
This following steps allows you to set the system time which will be displayed on the photos.
  • Press the Up or Down buttons to select the Date option in the Setup menu.
  • Press the OK MENU button.
  • Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken.
On selecting "Off" no date will appear on the photo.
On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken.
To Set the date:
  • Press the Up or Down button to enter the Set Date option.
  • Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
  • Press the Up or Down button to set the Date and Time digits.
  • Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
  • Press the OK MENU button to confirm, save the changes and exit.
You have done it.
I hope this solution helps you
If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
May 16, 2011 | Vivitar Vivicam 8225 Digital Camera
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
May 07, 2011 | Vivitar ViviCam X327 Digital Camera
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
My 84 year old mother has a 7022 how does she update date and time and also how do you remove date and time from appearing on the photo print thanks
In the shooting mode, press SET to bring up the menus. Use left/right to select the Date/Time menu. Use up/down to select an option and press SET.
The three options are On and Off for the timestamp appearing on the photos and Date Setup for changing the date/time.
Feb 20, 2011 | Vivitar Cameras
I set the correct date and time, but it does not display on the screen nor the photos. how do i get the date & time to appear on photos?
Sep 10, 2010 | Canon PowerShot A480 Digital Camera
I have a panasonic lumix camera. I wonder how i can print the date on the photo?
To print the date
You can set/cancel the printing with the
recorded date by pressing the [DISPLAY]
button after setting the number of prints.
The date print icon [ ] appears.
•When using the software “SD Viewer for
DSC” in the CD-ROM (supplied), you can
print pictures with the date by setting the
position on the print preview screen. For
details, refer to the separate operating
instructions about PC connection.
•When you go to a photo studio for digital
printing, be sure to order the printing of
the date additionally if required.
Sep 07, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How to make date etc appear on back of photos
The date usually only appears on the front. However, most retail photo labs (i.e. walmart) can add custom backprinting to your photos. You can usually only add one line of text for entire order and custom pricing would probably make this a little bit expensive. On that note, the date you have your film developed/printed is usually printed on the back of each print for free, as this is default setting for the lab's printer.
Feb 17, 2010 | Pentax Photography
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Jan 06, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Fuji FinePix S5000 Digital Camera Logo
43 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Fuji Camera Expert? Answer questions, earn points and help others
