Logitech LX 300 Keyboard/Mouse Logo
Question about Logitech LX 300 Keyboard/Mouse
Controller not working
The controller that plugs into the computer quit functioning last night. After reinstalling and testing of all the functions by my nephew, I discovered that my puppies had chewed one of the wires and it did not have a good connection. Is it possible to buy only a new controller? The mouse and keyboard were still working.
Posted by dlharper45 on
Anonymous
  • 42 Answers
Hi I am sorry to say that you puppies may have cost you a bit of money in this case from my own experience i found the it was easy to by the whole system for £10 than spend around £6 looking and may be finding the said part with no guaranties that 1) it was compatible with your mouse and keyboard and 2) that it will last the length of your mouse and keyboard.
Posted on Aug 21, 2007
2helpful
2answers
Night Hunter remote controller red light comes on wene charging but doesn't charge why
It is likely that the charger or the battery is not functioning correctly. If the battery is not taking a charge from the charger, then the battery may need to be replaced. You may also need to check the charging cable and port for any damage or corrosion. If the charger itself is not working, then it may need to be replaced.
Additionally, you may need to check the internal components of the remote controller for any issues. If the components are damaged or malfunctioning, then they may need to be replaced or repaired in order to get the remote controller working correctly.
Dec 26, 2022 • Cameras
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Microwave quit working no power everything quit working
use the next steps and fix it. test with the VOM. God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).14f03872-81cf-492a-a958-5a445dcde206.gif
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
1helpful
My controller keeps being unrecognized by any usb port and pops on and off at random
Hi, Please uninstall any LGS version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software, plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If your device keeps behaving this way, then i suggest you to contact Logitech support for hardware replacement as hardware failure are covered by warranty terms.
Thanks and have a nice day !
J -
I plug in the usb and its not repsponding..computer does not recognize
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
8helpful
Logitech Profiler does not detect my logitech dual action gamepad, why? I have a computer that uses vista 64bit.
Hi, Please uninstall any LGPS version present on your OS - Then please proceed to clean boot. -> Unplug any USB devices connected to the computer ( Less keyboard + mouse ) If you have a corded keyboard + mouse please use it rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software, plug the hardware when needed. -> Should work.
If a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If the problem persist, swap computer and try, if it does not solve then contact customer service for replacement
Thanks and have a nice day Julien
Keyboard not responding after login. I had a logitech wireless keyboard and mouse combo. I just purchased a G19 mouse and installed it. Now after I login, the keyboard stops responding. It is showing...
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
1helpful
2answers
I82801@P4BGV-MX audio ctrler invisible in devmgmt.msc
open device manager and i m sure that it will be given under system devices because all the devices that does not come under
unidentified devices are in the system devices list check it there or instead use some software like driver detective to find all the devices connected to the computer and get their device drivers
Open Questions:
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Marvin
Marvin
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
