Question about King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y
My king kutter till will not hold gear oil.
Do I need to buy a new one or can it be repaired with parts?
Posted by bphill9253 on
  • 1 more comment
  • bphill9253 Mar 24, 2009
    It is leaking at the large gear box on the left side. We put gear oil in and it drains out the bottom. I have not been able to locate anything on the Internet as far as replacement parts only the large gear box seems to be for sale.
  • Anonymous May 11, 2010
    Where is it leaking at?
  • Gerald Billings Mar 20, 2013
    use 000 gear grease or lubeplate that what King Kutter says, you are probably looseing the gear oil thru the tine shaft seal but they are very hard to replace. just use heavy gear grease.
Anonymous
  • 97 Answers
If it is leaking around the shaft you can replace the seal.
Posted on Mar 25, 2009
Anonymous
    New Friend:
Call Kingcutter at 205-487-3202 and order replacement seals.
Posted on Mar 29, 2010
Oil leaks out of shaft
hello, you have a bad axle seal that needs replacing,replace or keep putting in gear oil,
Feb 09, 2012 | King Kutter Ii Gear Driven Rotary Tiller...
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
How much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
Hi - recently bought a new KingKutter 4ft bush
go to kingkutter.com and download the manual.
hatter1
May 15, 2009 | King Kutter Pull Type Rotary Kutter 72in....
King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y Logo
1,906 people viewed this question
Top King Kutter Garden Experts
Charles Tidwell
Andrew Taylor
Andrew Taylor
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
