This hint is only possible if your hawking can be used a an access poit. if yes then try try the following:
connect you adsl line into your modem/router,
connect the lan cable of your modem into a switch
connect both your PC and Hawking into the switch
have your modem/router provide DHCP and DNS
configure your PC to gte its ip address and DNS dynamically
configure your hawking access point to also get its dns and dhcp dynamically (do this by getting into the hawking http page configuration, or telnet if you are good with commands)
now set a wireless lan with WPA or higher through your hawking.
there you have it.
doubts??? i have more solutions
