It seems like some of the minidiscs work and some don't. I know we can use +-R/RW, but does the number like DMR30L1 matter? Having trouble with maxell minidiscs.
DMR30L1 are Mini DVD-R Disc 1.4 GB 30min
Testimonial: "Not helpful. Didn't answer my question."
sorry about that if haveing problem with some of of the discare Defective a bad batch. And to anwswer your question this is your Model# DMR30L1 I hop this helps goo luck
sorry about that if haveing problem with some of of your disc are Defective a bad batch . And to anwswer your question this is your Model number# DMR30L1 I hop this helps goo luck
SOURCE: Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
SOURCE: Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
SOURCE: Sony Handycam DCR-DVD108 - Carl Zeiss Vario-Tessar Optical Zoom 40x
Please, I need support of camera technical carl zeiss vario tessar with otptical zoom 40x
SOURCE: How can i fix the "movie Recording Disabled" on sony DCR-DVD108?
Hi there. I undertand how upset you must be. I would be if it happened to me. Did you check the manual for this error code?
If you didn't, I'll tell you what it means. It means one of 2 things: 1) you have a bad disk or:
2) you are trying to use a disk that has been finalized. Once a disk has been finalized, it cannot be recorded on.
I'm sorry, I know it's a bummer, and it's not what you wanted to hear, but it happens occasionally. There is no fix for it. You just have to get a new disk and record it again.
Thanks for using FixYa, and if you have any further questions, just comment back. If you don't mind, please rate my solution a fixya.
Rob
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
