Question about DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking
Dead Delonghi toaster oven
Reto stye toaster ovenwhile using toast function, toaster machine would operate, then turn off, timer continue to tick, then machine would turn on again, even tho all switches in off position. Timer eventually stops. Remedied by unplugging machine after each use. Last week, used machine for roasting meat and ran it for one hour. the toaster oven turned off and would not turn on again.
Posted by eilenla on
Dave
    Scholar:
  • 53 Answers
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Posted on May 20, 2010
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Tip
Timer Switch Failures
Many toaster ovens use a timer switch to operate the ovens. Many of them use very poorly made Chinese timer switches that make a very poor electrical contact internally causing them to get very hot and in cases will melt connector insulation and also cause wall plugs to get very hot. One in particular is part # DKJ/1-60 which is used in Black and Decker and other manufacturers ovens. Replacement switches are about impossible to find and B&D will be of no help finding one. If your timer switch has only 2 contact tab's on it, you can use this tip to repair your oven. If it has more that 2 contacts, you will need to find a replacement switch or ask a qualified technician about other switches that can be used.
A safe and easy way to fix the appliance is to replace the bad timer switch with a single pole single throw toggle switch. Make sure to get one rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually, but at least you will be able to use the oven and not have to worry about a faulty timer switch overheating! The timers are for convienience only and you have to turn the OVEN feature on and off manually anyway so all you're losing is the timer convienience for toast or whatever and the toggle switches are much safer too. The switches can be purchased at any electrical parts store or at many hardware stores for under $10. A cheap and safe solution to the problem!
If you feel the need for a timer and want to take your chances with a timer switch, there are a couple switches that you can use to replace the DKJ/1-60 switches. They are made for Delonghi toaster ovens and are readily available. One part # is 5218104600. This switch will work the same as the original but it only has about a 15 minute toast timer. Turn counterCW for OVEN ON like the original switch. You may need to use some mounting parts from the old switch depending on your particular oven. Another switch which has a 120 minute timer is part # 5218101800 but may be a little harder to find. Both of these look the same as the DKJ/1-60 and are about the same size with the bell on the back of the switch.
on May 07, 2010 | Toaster Ovens
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
How do you set the delonghi convection toaster oven to cook chicken nuggetts?
Try this:
Thermostat knob - Toast/ broil
Time - 18 minutes
Wire Rack Position - Upper
Turn after 10 minutes.
For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
Regards.
Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Will Purchase Oven or Parts from Non-Working Oven.
Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
May 13, 2009 | Black & Decker CTO649 Toaster Oven with...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
DeLonghi EO1258 - Stainless Steel Toaster Oven with Convection Cooking Logo
468 people viewed this question
Top DeLonghi Toaster Ovens Experts
Marvin
Marvin
ray gallant
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
