SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
SOURCE: We have a Fisher & Paykel Smart Drive 9
Thank you to the gentleman who sent us the Manual. We now know that F & P has an automatic Lint Filter which is pretty useless !! Oh, for the old method of a physical filter you can clean...
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
SOURCE: My Fisher and Paykel Aquasmart leaves more dirt
Hi just read you posting.Have you tried the machine with the Efficiency button turned off?Has you machine got and LCD display or a series of buttons that light up?The reason I ask is, if you can select for your machine to fill to the top without clothes, then I have a way to remove most of the lint from your tub without removing the steel bowl.Please reply with the answers to the questions and I am sure I can help you throe this problem.
SOURCE: I have a 2008 aquasmart
This machine has an "inherent" problem with lint and it cannot be resolved by replacing an appropriate part because in the first place it has no lint filter.The only thing you can so is check and clean both the recirculation pump and the drain pump. Drain the machine then disconnect power and remove the fill hoses. Lay the machine on its front on a cushioned surface to access the pumps at the bottom of the tub. Remove the pumps and clean them including the inlet hoses and the diverter valve where both of the pumps inlet hose connect from.
Let us know if you need further advice. You
don't have to accept or rate this solution in order to post comments or
information. But accepting a solution will not stop you from
communicating with the expert. You can still communicate with the expert
as long as you need assistance regarding the issue stated herein.
