Question about Konica Minolta Office Equipment & Supplies
Konica-7222 Will we have konica 7222 copier machine which is getting jam paper in drum unit while we put A/4 paper in tray 1 but we are trying to set tray 1 A/4R machine copiyng but when 1st print out come machine show jam even we change setting for A/4R also, some one told me just reboot the machine so that issue will be solve but i don't know how to reset or reboot, can some one help me pleas...........
Posted by jasmiinfo on
gbamis samuel
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
The sensor did not sense paper passing through fusing unit.
check sensor by the side door, paper exit unit or paper passage
clean sensor, change if broken
check sensor spring
Posted on Mar 25, 2020
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: paper jam
There is either a jam in there somewhere where you can't see it, or if it clears, the feed roller is not feeding the paper, in either case you probably need a tech.
Posted on Jan 08, 2008
anokaba
LC Bajacan
  • 25 Answers
SOURCE: i face a paper jam a lot, what is the right steps to release it?
check the paper feed roller.it might be worn out already
Posted on May 17, 2008
alvinbga
Alvin Barnabas
  • 130 Answers
SOURCE: Paper Settings/RX Settings
Take the paper out of both trays
Posted on Jun 11, 2008
Anonymous
SOURCE: RECURRING PAPER JAM - BROTHER MFC 5860 CN
I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
Posted on Jun 26, 2008
Anonymous
  • 320 Answers
SOURCE: I HAVE A BROTHER MFC-8220
the drum comes out when you open the front door. it is where the toner goese.
Posted on Jan 20, 2009
My Konica Milnolta c224e display massage bye pass try could not be loaded
Sure it say that exactly never heard that before doesn't say "Replenish paper"? or does it give a code or jam indication
Is there any paper on it does this happen when printing or copying ? Trying to print paper or envelope? Do the draws work OK? If printing send the print job to the machine first the when the copier states replenish paper for the bypass tray put the paper there. insure your printer perfrancies match your setting on the copier for the bypass tray, such as THICK 1 or what ever
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 03, 2015 | Konica Office Equipment & Supplies
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Rear cover jammed
Hi madeleine,
1.Press the cover release button and then open the front cover.
2.Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5.Using both hands, gently pull the jammed paper out of the fuser unit.
6.Put the drum unit and toner cartridge assembly back in the printer (press firmly).
Fully close the front and back covers.
Pull the duplex tray completely out of the printer.
7.Pull the the jammed paper out of the printer or the duplex tray.
8.Put the duplex tray back in the printer.
9. Make sure that the Back Cover LED and the Paper LED are off and then, the Status LED lights green.
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-5460CN All-In-One InkJet...
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
I do not know how to remove the drum to fix a paperjam
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the Verify the message displayed on the LCD.
Warning: If you just used the machine some parts inside the machine are extremely hot.
2. Pull the jammed paper out of the paper tray opening. If you are unable to remove the jammed paper continue to STEP 3. If you are able toremove the jammed paper continue to STEP 9.
3. Open the front cover. If you cannot open the front cover, do not useextra force. See below for further assistance.
4. Pull out the drum unit and toner cartridge assembly. The jammed papermay be pulled out with the toner cartridge and drum unit assembly, or removing the drum and toner assembly may release the paper so you canpull it out of the paper tray opening.
a. If you are able to remove the drum assembly and jammed paper continueto STEP 5.
b. If you cannot remove the drum unit and toner cartridge assembly easily, do not use extra force. See below for further assistance.
5. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner. Hold down the blue lock lever on the left side of the drum assembly and lift the toner out of the drum unit. Examine the drum carefully for small pieces of paper that may be jammed inside.
6. Reinsert the toner cartridge in the drum unit until it clicks into place. If you put it in properly, the lock lever will lift automatically.
7. Place the drum unit and toner cartridge back into the machine. Use equal pressure on both sides of the drum unit when pushing it back into place. Make sure it clicks into place.
8. Close the front cover. Make sure it clicks into place.
9. Remove any remaining paper in the paper tray and then reload it. The tray can hold up to 250 sheets of 20lb paper. Do not over fill the tray.There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic. Fan the stack of paper well to avoid paper jams or misfeeds.
NOTE: If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed slot
10. Put the paper tray firmly back into the machine and unfold the output paper tray support flap before using the machine.
11. Turn the Brother machine around with the back of the machine facing you.
12. Open the back cover.
13. The black plastic inner chute should spring open automatically when the back cover is opened. Note: The inner chute has a diagram on it of a piece of paper being removed from the unit.
14. If there is paper inside the machine carefully remove it.
15. Close the back cover. NOTE: The inner chute will close automaticallywhen the back door is closed.
16. To test, print the Help List:
a. Press the REPORTS key located on the right side of the control panel.
b. Press the up or down arrow key until Help list appears on the display(#2).
c. Press Menu/Set. The report should begin printing.
Thanks an good luck
Nov 27, 2010 | Brother MFC-7220 All-In-One Laser Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
