Question about Jensen VM9510 Car DVD Player
Jensen uv71 volume setting
I have set my jensen uv7i to a turn on volume of 5 and now want it back to where it is normal so when I turn the unit back on it will be at the volume it was when I shut it down but can't seem to make it go back. I tried the reset button but it has no effect on the turn on volume I set it at. The manual does not tell you how to get it back to the defult volume setting. Can you help?
Posted by alienship200 on
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: JENSEN vm9510 NO VOLUME
I am going to assume you are making a standard DVD-Video disk, since the other format takes more specialized and much less common software. One likely possibility is that you have authored your disks with mpeg audio rather than Digital Dolby (AC3) or linear PCM (LPCM) audio format. MPEG format audio is commonly used in home DVD authoring but is seldom if ever found on commercial disks. my guess is that your car player isnt set to properly decode mpeg audio disks. I would suggest you go through the menus / owner instructions for your car player and find the menu setting which allows your car player to play back mpeg (rather than Digital Dolby or LPCM) audio, and your disks should then play fine in the car. Hope this helps.
Posted on Feb 15, 2006
Anonymous
  • 72 Answers
SOURCE: jensen vm9411 no sound
Check to make sure your vehicle does not have a factory amplifier. If you used a fit kit with wiring harness. try looking at how many wires were used in the factory unit compared to haw many you are using now. see if there are extra wires in the vehicle. If there is extra wires it is a pretty good clue the vehicle has an amplifier and will have to be rewired.
Posted on Sep 01, 2006
Ern Dissla
SOURCE: jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Posted on Nov 30, 2006
Anonymous
SOURCE: Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at [email protected]
Posted on Mar 28, 2008
Anonymous
  • 59 Answers
SOURCE: jensen uv7i
did you try resetting the unit?
Posted on May 29, 2008
Jensen UV7I Problem when i push my clutch in its mutes the sound.
i would check to see if a wire is touching the clutch pedal ,when its depressed.either its grounding out on the clutch arm or its a loose connection that is being moved by the clutch arm.
Mar 10, 2009 | Jensen Car Audio & Video
UV7I Volume Control Problem
they all do that ive tried you just have to deal with it it sucks but life goes on wright wright
Dec 17, 2008 | Jensen VM9510 Car DVD Player
Jensen UV7i Need internal amplifier
I own a shop either get me the PN off the IC. I will either have it in stock or, can order for you. Audiovox will not sell parts for this unit. But, they will service this unit for you. Call us @ 727-530-5221, Radioactive Car Audio #1 in Tampa Bay area since 1987.
Dec 10, 2008 | Car Audio & Video
Jensen uv7i
May 29, 2008 | Jensen VM9510 Car DVD Player
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Volume resets to 26 every time unit powers on
Jensen Units donot remember your previous setting, its just one of the many reasons not to get one
Mar 27, 2007 | Jensen VM9020TS Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Sep 04, 2006 | Jensen JR500 Remote Control
Jensen VM9510 Car DVD Player Logo
343 people viewed this question
Top Jensen Car Audio & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
