Question about Tomtom ONE GPS Receiver
Tom tom rider.new map. sd too small. new sd nothing works.
I attempted to download maps of western europe. sd card was too small. so i removed all data from original card but still too small. new transcend 4gb sd card( not hc ) will not work at all. now tom tom will not recognise either card and cannot be picked up on tom tom home, any advice on restoring operations without any back-up files would be much appreciated, detailed help essential as I am pc illiterate, many thanks
Regards Ian
Posted by ianmuzamurry on
  • Anonymous Apr 10, 2009
    Hi Ian
    I found this on ebay when I was looking at SD cards for the tom tom. Not a solution but It may help
    Dear sir,
    I hope the following information may be helpful to ebay customers who intend to purchase a new sd card for their tomtom rider. I recently purchased a set of european maps for my rider and these need a 2gb sd card as the original card supplied with the unit is not large enough.
    I duly purchased a sandisk 2gb card from a reputable ebay company but found that the card would not work with the Tomtom no matter how hard I tried. Please be assured that there was no fault with the sandisk card other than it wouldn't work with my tomtom rider, it works fine with my camcorder.
    Tomtom support was not really helpful and it was due to the kind advice of another ebayer that I solved the problem.
    It is important to but the correct card for the tomtom and the one I eventually found was a basic Kingston 2gb sd card which are vailable for about £45.00 on ebay.
    Unfortunately Tomtom don't seem to state that their units are incompatible with some brands of sd cards and the best advice I can give is check with the seller first that the card will work with Tomtom products.
    many thanks
    Chris
matt
  • 1,621 Answers
Posted on Jun 24, 2017
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: tomtom 1 (new edition) map of europe
I think you'll find that you can download it from tomtom home, with full technical help online & on the phone.
I dont advise COPYING it from a friend as you will get a symbol appear on the screen with a tomtom SD card with a large red cross through it, indicating that the tomtom knows its not a genuine copy.
Posted on Dec 16, 2007
Anonymous
SOURCE: tom tom one xl wont accept SD card with map on
Make sure the SD Card is formatted as FAT32 and not FAT. My TomTom One XL would not recognize it until I did that.
Posted on Aug 01, 2008
Anonymous
  • 158 Answers
SOURCE: Mistakenly formatted sd map
woops , where are you ? ( in the world ) and contact info ?
Posted on Nov 15, 2008
Anonymous
  • 158 Answers
SOURCE: cannot get map to work
First make sure you have a backup of your NEW ONE XL. You should be able to connect your XL to your PC using USB but not use TomTom home software. Your TomTom should appear in "my computer" as a drive . OR , put the SD card in a USB reader connected to a PC , that way you can look at and copy from or to the SD card.
You should be able to copy the map you have to the SD card directly ( if there is enough room on it ) , if theres not enough room , get a new bigger card , copy all the backup files you already have on your PC + the map you want. You might / should be then able to activate that map in the XL using the codes you say you have for the maps. if you try to do this using TomTom home it might have some restiction to stop you activating the required map but hopefully you should be able to do it manually as described above rather than use TomTom home. ... GOOD LUCK .
Please rate this reply if you find it useful .
Anonymous
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Posted on Mar 06, 2009
I have bought an S.D. Card loaded with Western Europe for my recent trip to England, but when I got there, and loaded the card, it loaded up and went to the front page, and no further, I sought advice from...
So it never work even on a different unit so the problem there can be with the SD card the data inside it might be corrupted, how about if y9ou check the content of that SD card to make sure data are still there...
Hope that helps.........
Sep 18, 2008 | Tomtom GPS
Can we download European maps onto our Garmin 200W for travelling with motorhome
If you bought the satnav in the USA it won't work in Europe. If you bought it in Europe you can download the maps but the full map of Europe won't fit on it. You can fit Western Europe or add and remove countries as you need them. It's probably not a satisfactory solution when traveling with a motor home. You can put the map on an SD card but the nuvi 200W has problems reading maps from SD cards of 2 Gb or more. The map of Europe would take a 4 Gb card to hold it all.
You would probably be better to buy a cheap satnav of Europe. You can get them from http://www.pixmania.ie/ie/uk/xx/617/xx/1914/23/criteresn.html?sSortInfo=Prix-ASC
if you want to buy on line or Halfords shops if you prefer to deal with someone face to face. Some of them cost less than €100 and would be near the same price as buying the map of Europe.
Or if you want a satnav that covers both the USA and Europe and will work in both the Garmin nuvi 1370 or the 2370 would do the job but costs a bit more.
I hope this answers your question.
Jun 07, 2011 | Garmin nuvi 200W GPS Receiver
Ipurchased amap for western Europe and Icant download it onto my ******* tom-tom.
Specific Maps are licensed to be used with specific devices. However, if your device has a card slot, and an additional map is stored on a card, you can choose which map to use.
To do so:
Press the change preferences
Use the right arrow key to change the page
Look for Manage maps
Tap Switch maps
A list of the maps available is displayed.
Select you wetern Europe map.
Jun 15, 2010 | Tomtom GPS
I have just bought a tomtom sd card of western europe overwritten with tomtom map of new Zealand.when inserted the tomtom520T just gets stuck on a tomtom picture page and nothing works ,any ideas,regards...
Assuming the maps have been registered for your device.........try resetting the device.
If the maps are not registered, it may eventually boot up, but you'll get a message saying that the maps are not authorised for this device.
Mar 04, 2010 | Tomtom GO 910 GPS Receiver
My new tom tom go 300 gps has nosd card with maps
If you don't have maps, you can't navigate.
So: Get an SD card. Download the maps.
Question for you: How did you wind up with a navigator with no card and no maps? You might consider taking it back to the place you bought it and exchange it for one with the minimum necessary to make it work.
Nov 23, 2009 | Tomtom GO 300 GPS Receiver
When i turn on the tom tom one
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Feb 24, 2009 | Tomtom One XL GPS Receiver
Cannot get map to work
Nov 12, 2008 | Tomtom GO 700 GPS Receiver
Tom tom one xl wont accept SD card with map on
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
1,168 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
