I have a VSFlexGrid Control Pro 7.0 used in my Access application.
Everytime i run my applications some popup window is coming about the control which i want to suppress it. i have another form in my application for which i am not getting any such popup. It says Licensed users receive latest version of the software. i just dont want this message popup while my application. Plz Help
It sounds like the pop up may be occurring because your Access application is not using a licensed copy or if it is licensed, it was not set up properly.
If you are the developer and you have a license for the control:
Do you see any properties that allow you to enter in some sort of license code or key? Try and compare the settings for the control with the settings for the control on the form that does not give you the popup. If you are a licensed user, then you should be able to get support from ComponentOne. There is a very similar problem to yours listed on their forum.
If you developed this Access application and If you do not have a license user then you need to purchase a license.
www.componentone.com
If you are not the developer of this application, then you need to contact the developer about this as they are the ones with the key for the control.
Good luck. Post your results.
