Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garbage disposal leak
Our Badger 5 Insinkerator is leaking from the red reset button on the bottom of the unit. Is this a do-it-yourself repair, tech repair, or time for a new disposal? Thanks.
Anonymous
Level 2:
  • Expert 247 Answers
  • Posted on Mar 23, 2009
Anonymous
Expert
Level 2:
Answers
247
Questions
0
Helped
166291
Points
834
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
2answers
Is there a reset button on the badger disposal?
If your garbage disposal won't run you may need to reset the garbage disposal using the RED overload protector button on the bottom. ... Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again. How to Reset Garbage Disposal InSinkErator
Use the wrench provided and turn disposer counterclockwise wise (of course the power is off.. do not repair it is better to replace with a new unit. Use 1/2 Hp minimum. Available at HD or Lowe's
Insinkerator leaking from bottom
Any leak from bottom part of disposal means replacement.
Copy following link for specific troubleshoot, and replacement steps with tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My garbage disposal is leaking through the bottom of the unit through holes by the reset button. Why is this occuring?
Disposal is rusted out and needs replacement.
There are no repair parts for disposals.
I wrote EZ do-it-yourself installation tips for when I worked apartment maintenance that will save time and sometimes money.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
4helpful
2answers
Insinkerator leaks water from the bottom. this is when water runs through. no difference if the unit is running or not
There is no repair, just replace the unit. Once they start leaking, that is fatal. you could not repair for less than replacement of the unit.
4helpful
The in sink erator model # 5-81A is leaking from the reset (red) button underneath. Help???
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
5helpful
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
heatman101
3helpful
I just noticed that my insinkerator Badger 5-75
heatman101
It Leaks.
heatman101
8helpful
Water leaking out of bottom of unit, near reset
heatman101
p
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
