When trying to turn fanmaster on electic the light keeps flashing and doesn't turn on. All the outlets have been open. I did get it working first time but next day I couldn't. Also the fan on the gas fire does not go round, is this linked??? Can you please help me out. Thanks
SOURCE: 1998 Suzuki Swift. When trying to fill gas tank service pump cuts
evap purge valve is stuck closed you need a new one
SOURCE: 2002 Ford F 150 Supercrew,,,,5.4.
try disconnecting the cluster fuse and the radio fuse and see what happen if everything work...u might have an open circuit or a short on one of the electronic in your truck
SOURCE: My Odyssey 1995 problem is now; after turning
It sounds like you're have a ignition harness(switch) problem. The igniton harness(switch) on this odyssey are known to go bad. The spring in the ignition harness(switch) sometime worn out or doesn't lock into the right position. I'll start by replace this first.
SOURCE: I try to find cigarette
Do you mean that you are looking for the fuse? The fuse for the cigarette lighter is located in the fuse block under the left side of the dash. it is marked "CIG". It is a 15 Amp fuse
NOTE: This fuse also powers your clock, air bag sensor assembly, remote control mirror switch and your shift lock. If this fuse is blown, you will also have problems with these items.
Your vehicle is also equipped with an auxilliary power outlet (Which looks the same as the cigarette lighter socket) it is powered by the fuse marked "*1" If this fuse is blown, only the power outlet will not work. This also is a 15 Amp fuse. (See picture below)
