Question about Intel Desktop Board D815EEA (BOXD815EEAAL) Motherboard
Can't speak with microphone,no sounds in microphone
I have intel D815EEA motherboard, i can only hear sounds but can not speak in microphone,i can hear my friend's voice in internet but they can not hear my voice, i checked all the settings but its not working,even i bought 2 new microphone to test it,but i can not understand what is the problem,what should i do to recover this problem? please suggest me...
Check the connection on the back of your case as there are two very similiar in color ports that can be confused. Make sure you have it plugged into the one with the mike picture.
Posted on Mar 23, 2009
Hello .i want know where power led and sw wire go connect on a emachine T3626 i desconnect my self and i forget where the go please help me
ftp://download.intel.com/support/motherboards/desktop/d815eea/a1696401.pdf
If you do not have pdf viewing capabilities, your browser will prompt you to install the plugin, please allow this install once you've followed the above link. In the pdf document, refer to table 48, on page 71 for how to connect your front panel.
Nov 22, 2010 | Zerus Intel Desktop Board D815EEA...
GPA Card for D815EEA ? What is the best performing GPA Card I can install on this motherboard for the money?...minor gaming (Diablo) and some AutoCAD 2007. Nothing 3D. I have a 25" HDMI monitor as well....
Something like this
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5699698&CatId=318
Everything better will be held back by your pc.
May 08, 2010 | Zerus Intel Desktop Board D815EEA...
I need the order for placing wires black in place. for front panel and reset, L ED. placement order for which they are placed back on the switch.
The wire placement is usually written small right on the motherboard. Each front panel connector should be labeled.
Here is the owner's manual for the motherboard:
http://download.intel.com/support/motherboards/desktop/d815eea/EA_ENGLISH.PDF
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Mar 22, 2010 | Zerus Intel Desktop Board D815EEA...
I can not find the matching pinsforthepwsw hdd led
Open the Intel link provided; http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/17793/eng/motherboards_desktop_d815eea.zip&agr=&ProductID=&DwnldId=17793&strOSs=&OSFullName=&lang=eng
Create a folder on your desktop and name it, Intel D815EEA
Download the file named, "motherboards_desktop_d815eea.zip" in to your Intel folder. The *.zip file must be uncompressed. You can download and install a 45 day free trial program called WinZip. Download WinZip from here; http://download.cnet.com/WinZip/3000-2250_4-10003164.html the program named Winrar will also uncompress the file; http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Once the either program has been installed open the Intel folder. Right click once on the file *.zip and from the pop-up window and click, Extract Here. You will need Adobe reader to view the PDF file. Adobe is free; http://www.adobe.com/products/reader/
Open the PDF folder. Open the "A1696401.pdf" file. This is the manual for your D815EEA board.
Open to page 69 motherboard layout. Item "C". Find pin 1. You can zoom in with Adobe by clicking the + sign in the tool bar. Than go to, Table 48. Section 2.8.3.3 page 71 in Adobe.
Front Panel Connector. Example:
Pin 1 is power for the HD_PWR = Hard disk drive, Power LED. Pin 2 is ground for the HD_PWR. ECT...
Case wire colors vary. Normally the solid colors red, green, blue and green are positive. Except black which is usually ground for the internal speaker.
The wire color solid white is usually - negative. So each pair will have a common wire color used for negative.
Hope you find this helpful.
Cheers!
Mike
Oct 17, 2009 | Zerus Intel Desktop Board D815EEA...
How to cnnect the light cables Power and reset............etc of intel mother Board d815EEA
Connector number J9C1 - power LED pin 2-4, reset switch pin 5-7.
1-3 - hard drive activity led, power switch 6-8 pins.
Connect and enjoy :-)
Aug 10, 2009 | Zerus Intel Desktop Board D815EEA...
Backpanel socket for microphone is not recognised. Speaker socket is alright.
in order to hear sound on the microphone you need to check the Mixer settings as the default setting for microphone (for playback) is mute as you would get some horrible feedback..
double click on the speaker icon in the bottom left and chose properties from the options menu you may (or may not) have the option to select microphone for playback, however there should be a setting for recording which should give you a slider to set the recording levels for the microphone, use sound recorder or other recording software to test microphone is working
Apr 13, 2009 | Intel Motherboard
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
I need a pin diagram.
pin diagram of motherboard....?which model...
Jan 07, 2009 | Zerus Intel Desktop Board D815EEA...
Computers & Internet Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
