I have brought my netvista from germany and i tried to turn it on this weekend but it won't. i swear it has dual voltage. is there any other things i should check? i've switch adaptors/plugs, still won't turn on.
appreciate any help.
ibmgermany
I had a similar problem. The IBM NetVista 8307 could not be switched on. I checked the powerswitch, the power supply, I have disconnected all connections inside...
After I connect the power supply to the mainboard while it was on electric power the board started to work ^^ !?
BUT... the BIOS made funny things and I could hardly boot up.
Solution: The small battery on the board (I think its an Litium 3V) was out of power. After I changed the battery the system is working fine now.
All the best for you,
Stephan
Hi there.
If you have brought your machine from a different country and it was working there, then chances are you will need a new power supply that is matched to your countries voltage, most countries have either 240v or 130v, you will have to check into this! be careful however as you can blow the motherboard up if you use the wrong voltage.
My advice would be to purchase another power supply from where you live and install that one.
Good luck and thanks for using FixYa!!
Do you have any power floppy.cd-rom,light on motherboard, fan any power at all. mysleuth
