Apparently there is a way to change the L2 column on a stat table to a frequency value--for example, if you put "5" in L1 and "7" in L2, your Vars stats would account for 7 different 5's.
SOURCE: L2 disappeared
Here's what you do in a TI-83 or TI-84:
Go to STAT > 1: Edit > UP ARROW > 2ND > INS > *List Name* > ENTER
Hope that helps!
SOURCE: in my stat function, instead of L1, L2 and L3
Press Stat. Choose "set up editor" from this menu. You will be returned to the home screen. Press enter and you'll get the message "done". This should fix the problem.
SOURCE: [Stat] - Data numbers (frequency) < 1 (not integer) on TI 85 Calc
Frequencies are always integers. They indicate how many times that particular data value came up. The data values may be non-integers.
As an example, let's say you're measuring the weights of widgets. You may have 3 widgets weighing 1.1 kg, 5 widgets weighing 1.2 kg, and 2 widgets weighing 1.3 kg.
Note that the data are non-integers (1.1, 1.2, 1.3) but the frequencies are integers (3, 5, 2).
SOURCE: Lost L2 on the stat edit function
Go into the STAT:EDIT function and Highlight L3. Push 2nd DEL (INSERT), and Put L2 back in. If there was data in List 2, it should reappear.
SOURCE: I want to enter in
The table is where the calculator displays values from functions entered in the Y= page. To enter numbers into lists, press STAT and select Edit to get into the list editor.
