The way to hook up the dvd player to the television to to put a cable into the output signal section of the dvd player( Ther may be many different ways to hook-up the signal s-video and component video, regular video. You must pick one of these output signal sources to put into the input section of your television by matching them up i.e s-video out to s-video input compnent video output to component video input, regular video out to regular video input. For each of these video hook-ups there will also be a set of two sound cables. Look on the back of your television for the signal input section and hook up the video cables and the sound cables to your selected input. You should do this with both units turned off in order not to damage the circuits by shorting them on cable insertions ofr causing heavy feedback in the circuits. One this connection is complete. Trun on the television first and select the TV's signal source . By pressing the input button and using the up and down arrows to find the correct selection. By matching up all three sources you now should have the correct signal path. Turn your DVD and test the controls. try using the volume control and use you dvd to to play,ff, or stop the dvd.If all this works then you have done the set up correctly and can now enjoy your dvd's on the television Hope this helps you with your problem..
SOURCE: we are trying to hook up a dvd player to our
You need to hook at the front inputs and set unit on video
SOURCE: Insignia DVD Player, Insignia TV, HDMI connection doesn't work
well a good hdmi cable should cost you over 100 dollars, so try a new cable. even though it looks like the cable is fine, it can be no good.
SOURCE: I have an Insignia 42"
First, I would check the connection to see if everything is in it's proper place and plugged in nice and snug.
Second, I'd try watching something else on the TV and see how it looks, I'd also try watching something using the same cable/input the DVD player is using. If that fails, try a different cable.
If your TV checks out, and it's your DVD player, it might be time to upgrade to Blu-Ray or buy a new DVD player.
Hope this helps, cheers.
Kevin
