Well first check the colour scheme of your monitor and of the projector. If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device. If you need further assistance please leave a comment. Cheers
Even though the lamp only has 200 hours on it , it could need replacement. It all depends on how the 200 hours was put on this unit. i.e. watching for hours at once - recommended.
Or in half hour sessions ?
At the end of the day the lamp of your Projector is the same as the ones you use in your house - it does'nt like being switched on and off for short periods
is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
