Hi my van acts like the fuel filter is plugging up, I have changed the filter, but it keeps happening. when going up hills it starts to lose power and chugs almost like there is a missing sound. Spark plugs and wires are new. Have taken it to 3 shops and no one cane seem to figure it out
SOURCE: spark plug wires
the firing order is stamped on the intake manifold. next time replace them one at a time.
SOURCE: car loses power, runs rough, like it is trying to choke itself
YOU have a bad coil pack. they are about $50. and not too hard to replace. the trick is finding the bad one. the good news is there are only 3 to choose from ( if its a v6)
SOURCE: Vehicle dies while driving down the road.
could it be the A/C pump kicking in. might be boging down the motor or electrical circuit, not letting the injectors get enough power. This could happen if the bearings are going bad in th A/C pump or there is a short in it. Just an idea. sounds like you have done the main components.
SOURCE: My 1998 Olds Silhouette van misses when carrying a
the egr valve.exhaust gas return.
i would also clean the throttle body
SOURCE: missing after replacing spark plugs
if it a v8 then your firing order is
cylinder on left side valve is 1-3-5-7 (left-right) & right side is 2-4-6-8 (right-left) towards front of the car to rear. Firing order is : 1-8-4-3-6-5-7-2-
if is a v6 then the firing order is
firewall side of the engine will be
2 - 4 - 6
Front of the car Radiator side will be
1 - 3 - 5
This is with you standing in front of the car
And if memory serves firing order is 1-6-5-4-3-2
