Question about Dell PowerEdge Computers & Internet
Flashing green light nic dell poweredge 1900 server
Flashes with cable disconected network seems to work but slow
5 Related Answers
Anonymous
SOURCE: Blue light flashing
Someone has pushed the system identification button on the front of the server. If you push it again the light will be solid blue.
Posted on Jan 30, 2009
SOURCE: flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Posted on Apr 29, 2009
Anonymous
SOURCE: Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Posted on Jun 11, 2009
JaxPlanet
Jax Planet
  • 923 Answers
SOURCE: nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
Posted on Jul 28, 2010
Anonymous
  • 60 Answers
SOURCE: Dell poweredge 1650 is beeping with blue flashing ...
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
Posted on Aug 16, 2010
I have problem in server dell poweredge 1900 it is orange light and wright error E171F PCIE fatal D4 F0 B0
Hi
Don't have a Dell, but the link below appears to give a solution that some people have found works for them
http://pcrepairpro10.com/dell-e171f-pcie-fatal-err-b0-d4-f0.php
May be worth trying.
Good luck
Jun 25, 2014 | Dell PowerEdge 1800 Server
All lights flashing rapidly
Indicators, Codes, and Messages
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
Aug 06, 2012 | Dell PowerEdge 1800 Server
PXE-E61 failure while booting Dell poweredge 2900 server
Its a Network boot process ( Earlier Boot Rom ) Disable in BIOS setup or Ignore it, install OS and use server.
Apr 06, 2012 | Dell POWEREDGE 2900 Server
Nic teaming on poweredge t300
Jul 26, 2010 | Dell PowerEdge T300 Server
Dell poweredge 1650 is beeping with blue flashing light
May 20, 2010 | Dell PowerEdge 1650 Server
Dell Power Edge 2600. It has an ERA nic but can't configure it?
The ERA is not like the more modern DRAC's ... it must be configured through the OS.
Feb 21, 2010 | Dell PowerEdge 2600 Server
Jun 10, 2009 | Dell PowerEdge 1800 Server
Open Questions:
Computers & Internet Logo
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
