Expert
- Posted on Mar 23, 2009
Re: Digital camera model 350D showing error 99
It is possible that the lens contacts are dirty. To fix this:
- Get a pencil with an eraser on the end (make sure it is a good eraser and not an old pencil where the eraser has gotten hard).
- Detach the lens from the camera
- Hold the lens so that the gold contacts are pointing down and lightly erase the exposed surface, cleaning them of any hand oil that might have gotten on them.
- Do the same thing with the gold contacts inside the camera body. This is a bit harder but doable (make sure to hold the camera so lens opening points down so no gunk falls in).
- You may want to use a lens cloth to 'dab' at the contacts afterwards rather than potentially blowing eraser bits into the camera.
If this doesn't work, here is some info from Canon support.
To isolate the cause of the issue, we suggest that you do the following:
- Turn off the camera.
- Remove the lens, battery, and CF card.
- Allow the camera to sit without power for approximately 20 minutes.
- Insert a fully charged battery, and turn on the camera.
- Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
- Insert the CF card.
- Turn on the camera.
- Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps:
- Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
- Reattach your lens.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician. If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Hope this helps,
Chris
