I have a craftsman LT2000.
It will start, but die when I let go of the the break.
It will die when I put the blade on.
It will die when I go forward or reverse.
Husqvarna Craftsman AYP OEM Riding Mower Deck Mount ... (Important) Craftsman LT2000 Lawn Tractor Lift Lever Grip ... How to Install a Craftsman Mower Deck.
You should have no problem getting the engine from a LT 1000 to fit in place of the original on a LT 2000. The physical space between the two mowers should be identical.
Try tracing the positive battery cable from the positive side to the solenoid to make sure those connections are clean and tight. Then from the solenoid to the starter. Clean and tight. Last of all please check the Ground to frame connection.
