Where is the model number on maytag quiet plus ii washer
Posted by Patty Mabry on
Rhonda Royer
    New Friend:
  • 7 Answers
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Posted on Jun 13, 2013
5 Related Answers
mikedurland
Mike Durland
  • 481 Answers
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
Anonymous
  • 25 Answers
SOURCE: Maytag washer not running
check the lid switch.
Posted on Mar 08, 2009
Linh Thanh
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II, Quiet Wash, Super
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Posted on Aug 13, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    MAYTAG QUIET PLUS II DRYER IS SQUEAKING
    It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
    Dec 25, 2012 | Dryers
    I have maytag jet clean quiet plus II model mbd6000aww. The jets are not spinning and the water is not spraying. I was hoping to get some DIY assistance. Thank you. Jennifer
    The most common thing I've seen causing this is when the holes in the spray arms ore clogged. Take the spray arms off and check the holes carefully for debris and clean out whatever you find.
    Feb 14, 2011 | Maytag Dishwashers
    Maytag quiet plus II doesn't spin. It makes a noise but tub doesn't turn.
    model number would be nice
    I have some info you may want to look at> I am thinking thrust kit replacement time:
    MY MAYTAG WASHER NOTES
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Apr 12, 2010 | Maytag Washing Machines
    I require a manual for a Maytag jet clean dishwasher, super capacity - Quiet Plus II, model number MDB6000AWW, serial number 13585595SY. Best quess is that the machine is 11 years old. It came with the...
    Your dishwasher was manufactured in November of 1986. Uh...its actually 23 years old, which could be why I had a hard time locating a manual for you. I was able to find a manual at the following link:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MDB6000AWW&siteCd=MT_EN_US#owners_manuals
    There's an Owner's Manual and Installation guide listed.
    If you need further assistance, please let me know. I hope this helps you.
    Oct 15, 2009 | Dishwashers
    Maytag Quiet Plus 2 dryer
    I can't speak for which one is best, but I I can help you fix the no heat problem.
    I am assuming it's electric heat. If it is, I bet the element has failed. If you know how to troubleshoot with a volt-ohm meter, I can walk you through the repair.
    Let me know if you have the wiring diagram, or can find it on the appliance. Also let me know if you know how to read one.
    Feb 01, 2009 | Dryers
    Washing Machines Logo
    344 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
