Question about Faberware FCP280 Coffee Maker
Need power cord for vintage coffee pot
Bidding on ebay for a vintage 1930's farberwear chrome coffee pot. all inside pieces are there but no power cord. where can i purchase one?
Posted by angiem767 on
Anonymous
    New Friend:
I am looking for an electric cord for a FABERWARE Vintage coffee pot, Model #325985 or 86. The plug in is 1-1/2" wide. If you can help me with this request, I would appreciate it.
Thanks
Wilkilene Smith
Posted on Feb 12, 2010
Switch turned on but no perculation.
If the coffee maker remains cold, the switch or the thermal cutout inside is bad. If nothing at all happens (no light, no heat), you may have a damaged power cord. Power cords may break at the plug if people yank on the cord instead of the plug to unplug the appliance. Sometimes the cord breaks where it goes into the pot if jammed hard against the wall or otherwise bent or twisted sharply there.
If you get heat but no percolation, look for clogged plumbing, such as lime buildup or a piece of paper towel in the percolator tube.
Sep 28, 2018 | Coffee Makers & Espresso Machines
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
I love vintage stuff. Where can I find good vintage teapots and teacups?
You can look or ebay or try sites like this one: http://www.theteapotshoppe.com/vintageteaware.html
Just make sure you are buying from a reputable site.
Jan 10, 2013 | Home
I have a vintage GE coffee perculator made in the 1930's and 1940's Cat No. 119P102 which I bought from an antinque store in Chicago 2 months ago. It has worked beautifully until yesterday morning...
The first problem is the time you will use a product of the very old time , and ask you not wonder what it mains happened in the interval between 1930 and 2016 maybe its not only the changeof 110V to 120 volts it is not much difference but far enough to worry and what the effect is on the heat dissipation of the heating element inside (the coffee must be too hot 90 and 95 degrees are normal all the cables and more parts of Should Be Replaced if it was not modifiedin all Those years, it Should Be modified, and it was modified there must be for shure a big wire resistor be Placed in serial to release to the high aC power on the heating element. and maybe many more parts. gaskets cables and more must Be Replaced iif not safety for all. preventinfo and usefull to a hot Become bitter tasting coffee temperature.
Sep 25, 2011 | GE Vacuums
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
Cord heats up electric percolator when it makes coffee. What is the problem?
It is not unusual for this to happen - particularly near the ends (the plug end and the coffee pot end). This happens due to one or more of the following: at the coffee pot end the heating element inside the pot is actually transferring to the cord connector and the cord, where it is exposed to room temperature air and is cooled down. The cord shouldn't be warm more than a couple inches from the end. At the outlet end and the pot end: can be caused by weakened contacts inside the outlet itself. Repeated plugging and unplugging cords during an outlet's normal service eventually causes the spring of the contact metal to fatigue. The weakened contacts do not "grip" the prongs of the plug, so the power needed by the pot has less area to pass between the outlet and the prongs of the plug. You only notice it on the high power devices such as toasters, hair dryers, etc.
You might consider replacing the outlet and seeing if the problem is reduced or goes away. In the case of the pot, the spring metal contacts are usually in the cord connector. Replacement of the cord should solve the heat problem in this case.
Please take a moment to rate this advice is you found it helpful. Thanks - and good luck!
Jun 29, 2010 | Faberware FCP240 Coffee Maker
Power cord for corning ware perolater model E1210
The electric Corning Ware pots are no longer made, so to find parts, such as the power cord, go to eBay. The model #E1210 uses a unique Corning Ware cord, so don't buy the standard looking percolator cords, as they only fit the early 60's models. It should look like the cord in the photo below.
Mar 15, 2010 | Hamilton Beach Proctor-Silex Simply Coffee...
I need a replacement electric cord for a GE Coffeemaker
Hi. go onto eBay and look for Corning coffee pot parts. bobbyone
Jun 16, 2009 | Faberware FCP240 Coffee Maker
Vintage coffee pot glass top
There are several of these for sale on ebay. Look there, and you can email the seller to see if they have, or know where to get parts. You might be able to buy one that has the part you need, but has some other problem so they will sell it inexpensively.
Oct 17, 2017 | Kenmore KBC12 Coffee Maker
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Faberware FCP280 Coffee Maker Logo
513 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Dael Escher
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
