Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westtell frequency How do I tell what frequency my Westtell 327 versalink Thank you
Posted by 3rabbits on
Isabella Lee
    Master:
  • Westell Wire... Master
  • 405 Answers
We are here to resolve your issue on belkin router technical support phone number1-877-7788969. For more information, click on http://resolit.us/Belkin-Router-Support.html
Posted on Oct 25, 2016
Anonymous
  • 44 Answers
Here is the link to Westtel Support and docs.
http://www.westell.com/technical-support/technical-support-2.html
You will need the exact model # for the manual.
ie: B90-327W15-06
I did notice that some models are handled directly from Verizon.
If this helps please let me know...
Tim
Posted on Mar 25, 2009
Retrive password for Westtell Versalink 3277 W
Just "reset" the router back to its "factory" settings, and then configure it, setting the password to something that you can remember.
1helpful
2answers
When i connect through the Linksy router I can't GET INTERNET
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
1helpful
Need usb wireless card for pc
Any brand should compatible with your Westtell, as long they have same range of frequency (i.e 2.4 GHz, 5.8 GHz), etc...
I will recommend 3Com, Linksys and D-Link.
P.S.: If this information was helpful, please rate this solution.
2helpful
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Westell Versalink, model 327W
if you are using the USB port of the modem, you should be able to see your modem while you are online, but if you are connect through ETHeRNET, you wont be able to see the modem on your device manager.
here is a USB port
and here is an ethernet port
12helpful
4answers
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
Model327w
Go to this link: http://www.google.com/products?client=safari&rls=en&q=Westell+VersaLink+327W&ie=UTF-8&oe=UTF-8&um=1
It lists some common prices for the modem/router combo.
Hope it helps.
2answers
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
2answers
Itouch with verizon dsl
powercycle the modem and try.
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Ekse
Michael Thomas
Michael Thomas
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
