Question about Maytag MMV5207AAS Microwave Oven
Shorted it while changint lightbulb
My husband was changing the lightbulb and somehow he got shocked. After he did the microwave stopped working. We checked the breakers and unplugged it plugged it back in but still nothing. Any suggestions on how to fix it or would be need a new one? Thanks!
Posted by ashlie0915 on
Anonymous
    Genius:
  • 1,066 Answers
Some microwaves have an internal fuse.
Posted on Mar 23, 2009
Ge wes1450ds1bb lightbulb stopped working
You usually have to take the cabinet top off to access the bulb. There will be screws all sides to take off before it will slide off.
Mar 02, 2014 | Microwave Ovens
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at [email protected]
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
Lg lmh2016st microwave shorted out after changing lightbulb now doesn't work
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 01, 2013 | LG LMH2016ST
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Vent and lights do not work on over the range microwave
Check for another fuse. Check all electrical connections for burns. Did you check fuse with a meter or just look at it? Don't trust what it looks like.
Mar 27, 2009 | Amana MVH210W Microwave Oven
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
Maytag MMV5207AAS Microwave Oven Logo
204 people viewed this question
Top Maytag Microwave Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
