Ariston L63. Dishwasher doesn't wash.. Two lights flashing.. Help!
SOURCE: Ariston L63 Dishwaher problem
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
SOURCE: asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
SOURCE: My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
we recommend u to perform the following checks on ur dishwasher,
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
SOURCE: my Ariston L63 has a problem at start of cycle
Looks like the main dishwasher motor is jambed. Need ro gain access to motor then move the vanes at the back untill motor turns freely. Retry.
